Beware Doug. You are right, if you say "a new sealing washer" but NO COPPER WASHER in combination with my impeller!!!
...The reproduced water pump impellers are made of high-quality aluminum alloy and hard-anodized to protect against corosion and cavitation damage.
The manufacturing quality and material quality of these impellers is significantly better than the original cast iron part.
But: The use of the original copper sealing washer is not permitted and can lead to material damage, because aluminium, copper and water is no allowed combination.
That's why the impeller will be delivered together with a special turned aluminium washer and a detailed information on installing.
And only this washer is allowed to use!
...And you're right, and this is a very important notice, not to forget the support ring on the camshaft-end under the impeller:
Sometimes this ring gets lost because it's stuck in the old seal, or it's so rusted that you can't even see it
It is also important that the sliding surface on which the shaft seal runs is clean and smooth.
The picture is showing a camshaft from a CX 500 Turbo that has been restored. Here we used a circular grinding mashine,
but I don't have that option anymore.
Of course, you can also grind the sliding surface with fine abrasive cloth.
You don't have to remove the camshaft for this. But you can work better if the
Boss, Cam Sprocket is removed.
