The project is as follows: Swap the rear end from a 1983 Silverwing Interstate (GL650I) to a 1980 CX500 Delux (CX500D).
I have both bikes and the Silverwing is a donor at this point. I like the appearance of Cast wheels that are on the Interstate and have swapped the front end to the CX500 to make use of the Interstate's heavier front forks and dual disk front brakes. To complete the modification, I would like to use the Interstates rear cast wheel on the CX500 as well. The problem is, the Interstate's rear axle is of a larger diameter then the one used on the stock CX500. The axles appear to be the same length. I believe I can over come the larger diameter problem by reducing the shouldered portion of the axle where it is held in place at the swing arm and using the Interstate's rear axle and rear end.
My question is this: Is the rear end ratio the same for both bikes? Are the Transmission gear ratios the same for both bikes? Does anyone know if the Interstate's drive line splines will match with those on the CX500D?
Any help or suggestions will be appreciated.
