21 - 40 of 48 Posts
Discussion Starter · #21 ·
I will check out that article about to go on an over night trip but to clear up any confusion I've added a video so you guys can see exactly what I mean.
Auto-tensioner play
its junk then
it is either the chicken or the egg in the broken chain act
the tensioner is supposed to one way lock out only
so the ball lock is not working on yours and you cant reuse it
i looked at the video and it does look like the lock is working for part of the travel but i cant tell if it si past
the range of use
you are not collapsing it fully and would have to release the ball lock to do it
but it looks odd
i will check this against a few i have spare later this morning to make sure and get back to you
Discussion Starter · #23 ·
Did anyone review the parts in the bottom half of post #15?? I got a little cash from some sales off eBay, id like to go ahead and order them either set since they are outside of the states. Thanks in advance
Generally you'd test them by digging your thumbnail into them. If you can leave an imprint they're likely good. If you can't the elastomer {or whatever it is} has hardened and may be brittle.
Bit hard to check with a long distance purchase though.
They LOOK OK.
Discussion Starter · #25 ·
Okay thanks! I've emailed the seller about that, and while I was looking I found a seller with a new aftermarket chain and the tensioner blade guide, and I had previously located another aftermarket blade or whatever you want to call them
201731
But numbers 5 and 8 now I'm waiting to here back a number 4.
Before giving up on the tensioner, I'd try resetting it. Once reset if the plunger still pushes in then it is FUBAR.
Discussion Starter · #27 ·
Okay, 1 how do I reset it, and 2 what about the rubber part on the end if it can be reset?
Use something like a screwdriver to push the ball in against its spring, then push in the plunger. While holding the plunger in release the ball, then release the plunger. The ball should now lock the plunger from being pushed in. See chapter 10 in the CX500E shop manual.
Reactions: Jennghigh
Discussion Starter · #29 ·
Okay just got back home, I did the afore mentioned procedure and the outcome is the same as the video I posted in a previous replay, no more or less travel. So I guess that means I need a new/new to me good condition one?
Also my manual doesn't show anything about servicing the auto tensioner not in chap 10 or the 650 addendum
201737
201738
201739
In the engine the plunger will be held in by the pressure from the cam chain and the tensioner. The ball and ramp is to prevent the plunger from moving inwards, releasing tension on the cam chain. If the plunger moves in without first pushing the ball up against its spring then I guess it is toast.
Discussion Starter · #31 ·
So the plunger moves in to about 50% spring compression, it doesn't go further than that, unless I push the ball in first as mentioned in the reset procedure. So I guess if it's moving that much it's bad? Sorry I'm so confused I'm building my knowledge on motorcycle repair as I go. This is my second motorcycle that I'm repairing, with some moderate automotive background, so I'm not a complete dolt just mostly lol.
It may be OK, I'm not sure. I have two engines with auto tensioner, have never opened either engine. I'm just going on my understanding of how the tensioner works. On the other hand, Murray knows of what he writes. Good luck, keep learning; let's do it together.
the ones i have will move a tiny bit when over extended in other words removed from the bike
this is when the ball is off the lock ramp nthe plunger will move less than 3/16 ofan inch and does
not move once it approaches the indicator hole
as i said your is junk sorry. your bike was driven with that chain and tensioner hammering for quite a while before the chain broke
it a very noticeable noise
Discussion Starter · #34 ·
Well darn lol! So I'll wait to see if Randall has a good spare to get to me. In the mean time, what do you make of this sound? This is the other Gl500 it's an 81 I attempted to rebuild Gl500 noise I hope it's not the cam
Discussion Starter · #36 ·
So I've got to pull that one back out to see?
Discussion Starter · #38 ·
Okay update! I got my parts in from Bertrum's a whole 11 days early heck yeah! And they look a far cry better than what I removed
202101
So now I'm waiting to hear back if anyone has an automatic tensioner I can snag or if there is a way to recondition the one I have?
And to my last question I got a stethoscope and I believe it is coming from the right valve cover that's where I hear it the loudest. And whilst waiting for other parts I also got Murray's quick sets in and I'm going to give that a go tomorrow.
I think I'm moving in the right direction now!
Discussion Starter · #39 ·
Additional update!
Ive been scouring the internet for the auto tensioner and I found a guy on eBay that has a 650 engine he's parting out and he sold me the chain guides and tensioner for 50 bucks! He tested the tensioner and the rubber on all is still soft! So hopefully I'll get that by end of the week and I can get on with my rebuild!
Since I already have brand new guides and a chain I'll install those and keep the others as spares.
202266
Discussion Starter · #40 ·
Well I got the tensioner in! I haven't installed it in the bike yet I wanted to test it too make sure before I did all the work. Here is a link of the tensioner compared to the one I took out. Let me know what you guys think!!
Thanks in advance! I'm off to the rodeo
21 - 40 of 48 Posts
