The GL500I that sat for 13 years is running today. I had to use the gas tank from my other bike as this one has a few small holes in it. The compression did come up and shows an even 120 psi via my gauge on both sides. (I think my gauge reads low but this is the bike that was showing 60 psi before running it so I’m happy)
Some remaining issues are: The gas tank has 3 small holes 1/8 to 3/16 about ¾” away from the petcock. I have not decided how to handle this yet. I used the tank from my rider to get the bike running. (Anybody have a good tank at a reasonable price?)
I bleed the front brakes and the wheel all but locked. I released the bleeders and the front wheel freed up. I’ve considered that the brake lines are clogged and/or the master cylinder. I removed the hose from the master with the reservoir filled and pumped the lever and no fluid came out? (I was able to bleed the brakes but that did take a lot of effort and seemed a bit odd) Question – should fluid shoot out of the master with the brake hose disconnected?
I’ll drop some spacers in the forks soon enough. The bike is also leaking some coolant but that may be because the reservoir is over-filled so I’ll get to that one later.
Any thoughts especially on the front brakes?
Thanks, Mike
Thanks, Mike
