I've been working on my GL500 for a couple of years. I've had it running for the last year or so and start it up every few weeks. No problem, even in the cold of the winter. I recently took it in for a safety inspection, the last step before I licence and insure it. I had a list of minor issues which have mostly been corrected. The other day, after putting a spot of weld on the front steering stop; it was allowing the triple tree clamp to touch the tank on full lock left, I started the bike and it ran for a few seconds the cut out. It would not restart, even with a boost. I tried again today, no go. It gave a couple of hints of firing but only after prolonged cranking.
There is fuel in the tank and fuel came out when I loosened the left carb bowl drain plug. Even with a shot of starting ether the bike would not fire. There is spark from the plug wire to frame when I test for spark. The valves, at least on the left side are moving and there is compression on that side. I have fuel, spark and compression but something isn't right. Any ideas?
