Hi guys I am new to this forum,bought a gL500 for spares for my cx not realising that they are almost completely different.my cx was misfiring when up. About 5,000rev,s also only run on one cylinder when first started, after some research found out that it was the pickup s which you can't buy or repair.so decided to swop CDI for to ignition had quite a few problems as you can imagine, no cam chain adjuster hole in casing on gL so decided to swop manual cam adjuster from cx to automatic adjuster from g.L small problem,the bolt on auto adjuster is bigger than on manual one,so drilled out the casing and retapped thread worked ok had to leave the straight slider in as it does not fit the casing of the cx.after doing all that casing fitted ok.so. On to the wiring,a lot of head scratching, but managed it in the end, but now I can't get a spark,I have checked both coils no secondary reading, have checked with David silver etc.discontinued.does anyone know where I can get coils to fit.thanks.eric
