1 - 3 of 3 Posts
I have a 1981 honda gl500. While riding sometimes the left side cylinder will not want to fire but i open up the throttle and it starts to clear out but it will continue to do it for a few seconds it mainly starts to do it crusing around the 4000 rpm mark. The mufflers are removed running ngk d7ea spark plugs and a k&n air filter. What could be the fix?
Plug wire?
It's been a lot of years ago but I had the same problem with a GL500. Turned out to be the plug wire. If you haven't checked the plug wires it might be worth a try. Good luck.
1 - 3 of 3 Posts
