Hi, and thanks in advance for your thoughts. I’m new in this group and bought an 81’ GL500 Silverwing Interstate, showing 54K on the odometer, a week ago. I’ve also read many threads here and often performance “issues” come back to carburetion.
This bike probably sat for at least 2 years as the last endorsement on the tag is from 2008. However, I was able to get it started and drive it 10 miles home running mostly or perhaps entirely on the left cylinder. It would rev up to 8k slowly and get on down the road. Once home I found that only the left bank was firing.
I pulled the carbs and cleaned and put it all back together now it fires on both. Now here is the funny part - now I can only get it up to about 5k on the tack. It runs fine up to there but just won’t make enough power to do anything above about 5k. Well in 2nd gear I can get it up to about 6K but it’s not working so hard.
I’ve check the timing and it is spot on. I checked the fuel petcock via pulling a vacuum and running about a gallon of gas out into a can and that looked great. (Had already put in fresh gas)
Compression is 140 on left side and 130 on right so that is fine I think. I have not checked the valve timing yet but I’m guessing it too will be spot-on. I have my curiosity about the power of the spark while it’s not as big as I’d like to see it is blue.
Since this is a GL Interstate I believe it does not have the issues of the ignition that the CX has sometimes above 5k. (I’ve read something about the “white wire” fix”)
So I’m thinking most of you will say to take a closer look at the carbs. With my past bikes most of my carb issues would be at Idle and not on the high-speed side. However, those carbs were not of the CV type.
Also, I’ve checked output to the battery while running and it’s right a 14 volts. The bike rides around fine and I’ve put about 150 miles on it but it’s not ready for the highway as I’m limited to about 55 mph.
Any thoughts about spark at the plugs? I might be back to the Carbs which I thought I did a good job of at the time.
Thanks, Mike
Thanks, Mike
