So, I've started my project to install a 1983 GL1100 Interstate Gold Wing trunk in place of the passenger seat on my 1983 GL650 Interstate Silver Wing. (Just tired of not being able to lock up my $700 worth of Arai helmet and Sena blue tooth communicator when out on rides.)
I've gathered up all the parts I should need including great condition GL1100 trunk and mounting rack plus a spare GL650 trunk that I can part out and use just the bottom, etc.
Going to use the bottom of the spare GL650 trunk to serve as the base for mounting the GL1100 trunk. Also going to use a 1/2" thick piece of high-density polypropylene (HDPP) to make a cover for the bottom of the GL650 trunk to serve as a mounting point for the GL1100 trunk and it's mounting bracket. Will cut away all but the top portion of the mounting bracket, just keeping the top components onto which the detachable trunk locks and secure that to the base.
So, right now I need some sort of trim molding, either plastic or rubber, to protect the aluminum trim piece on the top of the GL650 trunk base before I secure the polypropylene lid onto it. I could just secure it to the aluminum trim but the polypropylene is slippery and I would also like some protection for the aluminum trim to keep it from being damaged by the weight of the GL1100 trunk once installed. The aluminum trim is 5/16" wide. See pic below:
So, what do I use as a trim molding to cover and protect that aluminum trim before installing the polypropylene lid? And, where can I get some?
I appreciate any suggestions. (In the mean time, I'll get to work cutting out the lid.)
PS) Yes, I know using a GL1200 trunk would have been easier to mount because they are not detachable like the GL1100 trunks, but they just didn't look right on the bike. The GL1100 trunk matches the look of the bike and saddlebags much better. If this works out, I'll paint the trunk to match.
Should sit about like this when I'm done, but a bit taller with the mounting bracket under it.
So, again, what can I use for trim molding to protect the aluminum trim?
