1 - 9 of 9 Posts
Hi
I've searched the Web to no avail on this one.
I'm after centre hole size, bolt hole pitch and diameter, and offset on 1983 gl1100 front rotors.
These are the 10mm wide ' double ' rotors.
Much appreciated
Jay
Discussion Starter #3
Yes murray, 1983 aspencade.
Discussion Starter #4
I have 1983 aspencade front forks on my ' bitsa ' build, and I have an 18" cx650e front wheel I want to put on. Just want to check what rotors I can get to work with both.
i have this in some drawings of some fuckery i was doing on rotor
swapping of a gl wheel onto something i needed blackbird rotors on
it is for the non vented rotors on a standard so the min/max rotor thickness will be off a bit
Outside Diameter 276
Inside Diameter 58
Bolt Hole Circumference 78
Bolt Hole Quantity 5
Bolt Hole Size 8.5
Thickness 5.0
Minimum Thickness 4.0
Offset 26.0
Discussion Starter #7
once again thanks for that murray. that is excellent news as the gl1100 rotor will fit straight onto the cx650e front wheel.
now i just got to find out if the gl1100 rear caliper will play nicely with the cx650e rear wheel/rotor.
Discussion Starter #9
Agreed fella it is a lump, looks like it’s the same as the front two. Ideally would like to use as many bits as I can that I already have, so will give it a go.
1 - 9 of 9 Posts
