1 - 7 of 7 Posts
Good afternoon, I have acquired a poorly cx, its my first project, I'm modifying it with a monoshock and having a cafe racer style, I'm going to convert it to upside down forks and want spoked front and rear wheels, I've hered a gl1000 rear wheel is a possibility, what type and year would I need and what modifications would I need to make? Thanks, Jack 馃檪
Welcome, Jack!
Especially with this being your first project, get it into running condition first. After everything functions, start making incremental changes. If you start by cutting parts off chasing a particular style, the odds that you'll find yourself over your head and giving up increase tremendously.
I know I should start by getting it running, but there's all sorts I need to replace anyway and I know my dreams of what I want it to look like won't allow me to just get it running, I want a challenge and I am an engineer so have some expertise in some topics, any help is appreciated, thanks.
There is also the pain of spending a bunch on fun parts and plating and powder coat. Then when its time to fire it up it doesn't. then you realize it will need a complete rebuild and then that some parts are no longer available. You may not want to get it road ready but I would suggest you at least fire it up!
Welcome to the forum. Please add your location and your bike's model and model year (NOT year first registered as UK paperwork shows) to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
One example of dangerous mods is converting a CX500 swingarm to a monoshock without adding serious bracing to strengthen it. It was designed to be supported by the shocks and putting the force at the end near the pivot will put large bending forces on it that it may not be able to withstand.
Don't get me started on wire spoked wheels. They are so inferior to Comstar wheels in so many ways that changing to wire spokes is a huge step backward for no reason other than "style".
1 - 7 of 7 Posts
