Hi,
My name is Dave but on other forums I go by user name FuzzFace2.
I have not had a bike since the mid 80's because of life and living in New England at the time did not give a lot of good riding days.
In 2015 moved to NC and needed to move my driver Lic.I needed to retake the computer test to keep the MC part, I also have a CDL Lic. for my job as a truck driver.
Wife asked them why I wanted to keep the MC Lic., "we have 90% good weather down here that is why".
Few weeks ago I came home with a 83 GL650i Silver Wing Interstate (I know this is a CX500 / CX650 but seen some things on the interstate) with 37,400 on the clock.
Had not been on the road for a little over a year and the seller said would not run because of gummed up carbs. Looked to be in pretty good shape for the year.
Also told the cooling fan did not work so if sitting running it would get hot.
I am the 3rd owner, always kept in a garage, forks & swing arm bushings felt tight and steering smooth when turned. Battery tender was on the battery but it cranked over slow but no rod knocks that I heard.
I picked up carb rebuilding kits, a fan switch and a used fan (was cheap and did not know if I could find it if needed). I also got the FSM (hard copy) and tit helped on pulling the carbs for rebuild and the cooling fan issue.
In pulling the tank to get the carbs off I found the petcock would not pass fuel?
Pulled petcock apart and found the rubber stuck to the body but in good shape.
He ran 0E fuel and had the tank full so it would not rust over winter.
Carbs were clean inside but sprayed it out just because.
Carbs back on and gas feed from a bottle so I could get running and not need to pull tank again if needed. She fired up and ran pretty good but needed some tweaking.
Sorry so long will start a "project" thread.
Dave ----
Dave ----
