Is it pressed on, or just stubborn? Any ideas and/or tricks for removing it would be GREATLY apreciated.
So I guess what it boils down to is to get a bolt the same size as the one that holds the fan on but longer and screw it in right, or am I still missing something?I use the rear axle bolt. fits perfectly and always takes it off with no problems.
no,its bigger than that bolt.buy the bolt quoted above,and youl be fine.So I guess what it boils down to is to get a bolt the same size as the one that holds the fan on but longer and screw it in right, or am I still missing something?
Koooool!!! Thanx guys. I really appreciate the info.no,its bigger than that bolt.buy the bolt quoted above,and youl be fine.
fan retainer bolt screws into the shaft
fan removal bolt screws into the fan
I took the nut off of my rear axle and found a bolt that threaded into in and that worked great. I didn't want to pull an axle if I didn't have to. Ended up going to a motorcycle shop to find the bolt. 14's are kinda hard to find.I actually remember using the front axle....worked like a charm.
"The front axle has a nice taper to it so only 1 or 2 threads engage the aluminum fan hub. Thus the possibility to strip out the threads. The rear axle (cx500) is actually better to use than the front axle. Better you take the nut off the axle and take it to the hardware store and get the correct metric bolt."I actually remember using the front axle....worked like a charm.
agricultural supplies normally have themI took the nut off of my rear axle and found a bolt that threaded into in and that worked great. I didn't want to pull an axle if I didn't have to. Ended up going to a motorcycle shop to find the bolt. 14's are kinda hard to find.
That quote is from a post at the old forum by Dick in Raleigh,,if the fan is stubborn(as some are)you can cause yourself more grief than good by using the front axle.
Wow, Gary. You are a credit to the forum to make such a offer. Do you have a estimate of what the shipping would be to Antarctica? Does the $12 per day start when you ship it, or when I get it? How about return time? Can I get one that doesn't have FAN written on it? Will you accept 8 track tapes in lieu of Paypal? Can I combine offers and rent more than one at a time? Until these vital questions can be answered, I may just have to wear out the one that I got from Ace Hardware.
The fan hub is threaded on it's inner hub to take a 14 x 1.25mm bolt. Screw one of these into the hub and it should pop right off.
