1 - 9 of 9 Posts
Putting thing back together again after triple bypass and noticed that the gear shifting doesn't feel like it's working. Attaching a photo. The only part of the shift mechanism that was disassembled in the process was the left shaft to install a new spring. Any ideas?
Dan
I've always found the best way to fit the rear cover is to fit the output shaft to the motor and an 8 mm stud or bolt with the head cut off fitted to the top hole.
The cover is put onto these as a guide and pushed straight back. The alignment is done for you.
Then fit 2 8 mm bolts to either side, nip up and check the shifting {while waggling the output shaft} before putting in and torquing the rest of the bolts.
Torque the 8 mm bolts before the 6 mm bolts.
Are the shift mechanisms 'claws' engaged with the pins here?
I might have assumed wrong. I was thinking the shifting issue was discovered before attempting to install the cover based on the attached picture. Is the shifting issue with the cover on or off or both?
Discussion Starter #6
I made the rookie mistake of not checking it before installing the cover, Had to remove it. But the shifting still doesn't feel right.
Dan
Discussion Starter #8
Got it. Thanks guys.
Murray, any luck finding that seat pan?
Dan
1 - 9 of 9 Posts
