Finally got the nerve up to run until I needed to switch over to the "reserve" position. Got to 335 km (208 mi), some major engine stuttering...switched over to reserve...all OK again. Pulled into a gas station only 1km from switching on to reserve. Took 16.1 litres (4.25 US Gal or 3.5 Imp. Gal). Fuel mileage was 49 MPG - US or 58.75 MPG - Imp. Gal.
The question is....what amount of fuel was left over in the tank when I needed to go to reserve? When I popped off the fuel lock, I shook the bike side to side, but didn't see (or hear) any fuel. Obviously there must have been some in there...but how much?
I guess the real answer is to have a couple of litres (pre-measured) of fuel in a separate container on board, then do this exercise over again, but this time drive with the reserve "on" until it runs out. Add the carried fuel, drive to the nearest gas station and fill up. Calculating the fuel needed to fill (including the fuel added from the container) to fully understand how much fuel is on board when initially hitting the reserve postion.
However, before I actually do this (yes I probably will do it sometime), if you know the volume of fuel in the tank when the reserve go on, I'd appreciate knowing...and hearing from you. JC
