beginning to reassemble my handlebars/etc in the front. what a nightmare...
i am pretty sure my horn is dead. I'd tried all the trick some of you recommended, but getting nothing
BUT - it could be a wiring issue.
1st off, there are 2 wires which go into the where the clutch grip goes. Inside there is a small pin which, when the clutch grip is not pulled, I figure should be depressed in.
Why is a horn wire going there?
I can't for the life of me get the small brass screws out of the insides of this part. I want to disassemble, and check out WTF is the problem. Everything else works inside the assembly; turns/headlight.
accoring to the manual, the GREEN and BLACK wires are for the horn. all green? or the green with red stripe?
