1 - 16 of 16 Posts
Shep,that seems very good value.when you compare the cost of just 1 acv.
interesting to see what Larry makes of it,at least cost wise.
Not sure if that Diaphragm is for an ACV or accelerator pump or are they the same ?
mmm,i did not look that hard,just took it for granted,as i dont use the pump.
if they really are acv,s....its excellent value for money
I don't have any accelerator pump type carbs so can't compare or vacuum petcocks?
mmm 2 in the picture,and this quote
Each kit contains all necessary gaskets, O-rings, float valve assembly, float needle, main jet and pilot jet to rebuild one original carb
I just ordered a carb kit from the same Ebayer. I will be interested to see if we all have any luck with this kit. I hope to start on my carbs next week.
Does anyone know if this will work on the GL 500 carb?
Stubby,pretty sure most,if not all would be fine with the gl carb.
if it comes with 2 kits,for the price quoted,then id order it.
1 - 16 of 16 Posts
