ok,ill disagree with the guys.............So I bought some new fuel line, hose clamps and a filter. Question--does the length of the line matter? Is there a too long/too short that will affect performance?
Thanks,
DW
too short........it wont meet,fuel on the floor
too long.....youl end up with a bend/kink you do not want.there is not much play between your tank petcock and your carbs.it has to be right.![]()
after sleeping on it,ill have to correct myself as well.Totally agree....to make mine fit better with the filter I simply turned my petcock about 45 degrees toward the back (normally it faces the side of the bike)...works great for 2 years now. You can kind of see how I have my petcock turned in the close up pic of my carbs and valve cover in my sig below.
These are the ones I like but it could be a trick to find them. It's a K&N 90 degree filter. Well worth ordering if you cant find them locally. Don't get mesh filters get stone filters. They are a lot better.
http://www.clarkemfg.com/cart/index.php?main_page=product_info&products_id=348
When I first got my bike I removed that "finger screen" from the inside of the tank....never replaced it since I have the inline filter...no harm done.
Thinking about removing the petcock finger screen in the tank, and
mounting a common Toyota Pickup paper element fuel filter below
fuel tank level & above the carb level, above the battery & behind
the side panel.
Auto Zone: FF4417
Hastings: 8163-05041520
Purolator: F29157
There is plenty of room:
