I cleaned the carbs relly good last month in the ultrasonic cleaner and the bike is was running pretty good. I am trying to balance the carbs now that they are cleaned. I made a rig out of 2 mason jars with a crossover line and filled them with oil. the one side is running stronger and sucks oil across the line. ok screw the little screw in and then it goes the other way. try backing it till it is good. then when i tighten up the lock nut i disturb that little tab and push down against the spring and it throws everything out. not just a little like a 1/16 turn. It takes like a 1/2 a turn the other way to take all the slack up and get them balanced againg. I have been going back and forth for like and hour.(because I have to let the bike cool off) what is the trick? maybe my adjustment tang is loose or spring is weak or something. about to just give up and drive it out of balance because I can't see how it would stay the way you leave it with all that spring loaded slop between the 2 butterflies.
