1 - 17 of 17 Posts
1980 Honda Cx500C
I have a 80’cx500 just did a restore on it. One of the things being turn lights. For some reason the fronts aren’t blinking but the rears are. I have new turn relay, and I’ve checked the grounds/wiring. Any ideas?
Also noticing weird engine noise almost like a whirring coming from the right side at slow right hand turns. Gets louder as I lean the bike over.
Does this, "... I’ve checked the grounds/wiring...", mean that you have checked to see that you are getting current at the front turn signal lamp sockets?
Reactions: washoe
Have you installed LED indicators? They won't draw enough current to cycle a thermal flasher.
Reactions: D-Fresh and washoe
Well the running lights work they just don’t flash
The front signals have two power feeds, one for the running lights and one for the turn signal. The power to a running lights is cut off when the turn signal is activated. Does the running light turn off when you turn on an indicator?
1980 Honda Cx500C
Yes if I were to turn in the left signal light the running light turns off and nothing happens it just stays off we’re the rear light will do a hyper flash and then turn to a stale light with no flash just stays on. Until I turn the signal off.
Have you replaced the signals or are they the original ones?
If they aren't original please post a link to what you have.
The front signals for these bikes should have 3 wires: ground, bright filament (signal) and dim filament (running light). Have you checked that they are all connected correctly and that both filaments of each bulb is working?
1980 Honda Cx500C
Yeah the running light turns off but doesn’t proceed to flash, I have new flasher relay and cleaned switch and double checked my wiring with my manual. The rears flash when I turn my signals on.
1980 Honda Cx500C
Discussion Starter · #13 ·
I bought a random pair off of my local shop that specializes with Hondas. It’s a 2 wire led turn signal. I’m not to sure why they would give me 4 of the same turn signals if they knew it couldn’t work. So theirs gotta be a way. The rears flash, the front running lights turn off. But don’t flash
1980 Honda Cx500C
Discussion Starter · #15 ·
Which wire did you not connect if there are only 2 wires on the new signals?
Well the stock turn signals only had two wires when I took the out (orange/white orange) and
(blue/white blue) so I I hooked it up the only way I could. If I switch the wires I have nothing but at the state I have it at only the runners work.
The stock indicators ground through the mount. Your replacement is a simple, single circuit. If you ground the second wire, it should flash, but you'll lose the marker.
To make it function properly, you'll need a smart relay. There's a design around here somewhere.
1 - 17 of 17 Posts
