The frustration.. continues.... discovered all three brake lines plugged.... thankfully we have a local spot that builds them..... the 500 gauges mount to the 650-gauge bracket... the center dash cluster on the 500 mounts with two horizonal holes.. the 650..two vertical holes.... break out the drill... with the wide dual forks... the lower triple tree steering stops (blocks) need a small section added (welded) to prevent the upper fork touching the fuel tank. Thankfully I know a welding guru.
