I dunno if I should really be worried about this, everyone I ask says that there's a problem but they don't know where it's coming from or how it's happening, and frankly, I'm a bit stumped as well. Only about 1-2k miles after rebuilding the front caliper and master cylinder and putting in new pads I noticed decreased braking power. Seems as if I have to pump my brake to make it work the best that it can. It's the worst in the morning when I'm going to take it for its first ride in the day. When I was on my latest trip I could tell that the master cylinder was leaking. It looked like it was around the banjo bolt, but I was told that if it was leaking there, the bolt would always be wet....though it seemed like it'd only leak after continously going long miles. My guru-uncle thinks it's leaking from the top of the master cylinder. I saw fluid appear there, around the banjo bolt, some sprayed onto my gauges, and once some pooled up on the brake hose (it kind of curves down a bit). I only saw it leaking when I went on my trip, now riding around town the only evidence of it is feeling moisture when running my finger along the cap. The quality of my front brake gets even worse when it rains, I either have to pump it more, or the pumping won't even make it better.
I'm stumped on it...I rebuilt EVERYTHING in the front brake system, though we are using the old brake hose...though I doubt that that would cause this kind of problem.
The only related issues are in the front end. I have a new one, I just haven't had time to put in the fork seals or anything yet. Seems like the current forks may be bent, the pistons inside of the forks are gunked up, and I just have a very stiff ride. I don't think that this would really create that kind of problem though. My mechanic says that he thinks that it's dragging, upon watching me struggle to push it into his garage (I stopped by to buy some plug caps, and it was raining, and he let me push it into his garage to keep it dry). It doesn't make any noise like when it has dragged in the past though. Maybe I shouldn't worry about it until switching the forks/front end? Or could it be something else entirely?
