I bought a GL500 Silverwing this spring and found out very quickly that I needed front fork seals. I ordered a set and they have now spent six months sitting on my desk. I have watched about a dozen video's on replacing them and all but one had me tearing down the whole front of the bike. There was one that left the fork tub in place and worked from the bottom. It looked a lot easier and I you don't have to mess with the air lines on top. Her are my questions, has anyone ever done it this way, is there any reason not to do it this way and has anyone else seen this video. I also can't find it online to watch it again. I have done forks on my CB175 about forty years ago which was a much simpler job and I was a much younger man. So, if anyone can give me some insight it would be greatly appreciated.
Personally I would do the full removal and strip down as they're likely full of sludge that was once fork oil and will need cleaning out.
The fellers here can talk you through any issues that arise but maybe the job isn't actually as difficult as you think.
I recently rebuilt about 6 sets of CX forks. They're not difficult and the GL forks aren't vastly different.
... you don't have to mess with the air lines on top....
The air lines on top are very easy to deal with.
Have you downloaded a copy of the factory service manual from the wiki (see link in my signature ) ?
I can't believe you've been on the forum this long and I haven't welcomed you to the forum. Please add your location and your bike's model and model year to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
As for the forks, I agree with Phreak about doing the full rebuild the first time. There could very well be 40 years of accumulated sludge in there.
This could be a good time to think about eliminating the air hose too. Its sole purpose is to make it so that you only need to check the pressure once for both forks but if a seal suddenly fails it will let the air out of both forks and the front end will collapse.
When I hit a pothole on my GL500 sidecar outfit and a seal let go I was only 30 Km from home but I still remember feeling it bottom with every bump almost 20 years later. Not long after that I eliminated that hose so that if a seal let go there would still be at least some suspension.
It might also be a good time to think about adding preload spacers to the forks to improve their performance or even eliminate the need to add air pressure
