1 - 14 of 14 Posts
1978 CX500 Suzuki V-strom 650
As a new owner of my 78 CX500 i want to go and tackle a bunch of tasks. Being one of them is changing the fork oil to a heavier weight. I also want to put some fork protectors on.
The seals and fork tubes are in good condition.
So my question is, is it possible to change the fork oil without disasembling them by removing the forks and pumping out the oil?
Daan
There's no drain plug on the '78 fork. You'll need to remove the cap, remove the tube from the steering yoke, and invert the tube to drain the oil.
Alright sir, thanks for the answer! I was already thinking of doing that, but was wondering if it was do able like that.
Glad a don't have to pull the forks completely apart.
You might want to, depending on how dirty the oil is.
If the oil is really dirty you could drain it then flush with kerosine , giving the whole assembly a vigorous shaking to really free up the crud.
Reactions: Randall-in-Mpls
I imagine it wouldn't be too difficult to add drain screws to them while they are apart so you can change the fluid without disassembling them the next time. The drain screws are usually just regular Mg screws with crush washers (either aluminum or copper) to seal them. The hardest part (if you don't have access to a milling machine) would be getting the area under the screw head flat and that would only require some patient work with a flat file.
As infrequently as these need service, I don't think it would be worth the extra effort (and risk).
There are many different opinions on the frequency of oil changes. On the BMW Airhead forum most of the respected and known experts say it is an annual job. I don’t necessarily subscribe to the idea that it should be done that often but I do believe it should be changed more often than most people get around to changing it (it gets changed when replacing a blown seal). If there were drain screws installed more people would probably actually change the fork oil as maintenance rather than only when fixing it.
Sometimes where there is no drain plug, some riders do a flush with forks removed as outlined.
Subsequent changes/or "playing" with fork oil viscosity are done by extracting old oil with an airline/vacuum line from the top (fork caps removed) with forks insitu....haven't tried this on the CX myself....
Last time I did it the oil was undoubtably original and 40 years old, and was a thick gray disgusting sludge.
Then it was about due. ;)
and smelled like roses i'm sure... :p
1 - 14 of 14 Posts
