I don't understand the concern. The headset only goes in one hole with set angles. The fork legs go in the already installed triple, and the front wheel clamps in the bottom the forks assuring they are facing correctly. The internals of the forks are held by mechanical tolerances and the bottom half of the fork does not care what its rotational relationship is to the top half and vice versa.![]()
Rick,i think thats the norm.my 81 [sunflower]had to be driven out.I know it seems that straight forward to most but this is my first go at a bike, and I just wanted to see what the 'norm' is, and if there were any techniques, order of operations etc; I am not out to reinvent the wheel, just curious mostly, and proper alignment seems pretty important to me.
The thing that prompted the question was the replacement of the fork tubes seemed to take much more effort than it did to remove them...when I loosened the triple bolts, I just lightly tapped the fork tubes and they slid right out.
What? Why do this? So just tighten the top clamps on the forks and take the bike off the center stand? Leave the lower clamps, fender, and axle nut loose? Tighten them when on the ground?Take the bike off the center stand and bounce the front end up and down,roll it forward,and hit the brake several times..(note do this while sitting on the bike)or bump it against a wall gently
Tighten up the lower clamps,
Then if you really want take a string or long straight edge and check the alignment between the front and rear wheels.
