1 - 12 of 12 Posts
I know to get the flywheel off the drain plug from a subaru is recommended. So i picked one up and just like recommended I glued on a washer to give it a little more length.
It fits and seems like it would work but I can't get the darn thing off no matter how hard I try. All I end up with are smashed washers and no luck with the flywheel.
Is there something I could be forgetting? Any ideas why it won't come off?
Yup. They are a bugger. Get the bolt good and tight and then give the bolt a few good smacks with the hammer of persuasion. You wont hurt anything but your washer. What is keeping it on there is a key, and it gets "sticky" after years. So with the bolt in there tight, ... you are pulling on the flywheel. Then with the taps of the hammer on the bolt, I guarantee..... tap, see if it loosen up, tap, check again... and continue. With this technique it's not hard.
Do you have an air impact wrench to use. That is the slickest way to pop them off. Without one of those, try adding a thicker washer and when you have the bolt as tight as possible, rap the end of the bolt with a 2-3 lb hammer. Then try to tighten the bolt and repeat. It should pop off after several tries.
I work on cars all day long. I tap the ends of pullers every time I use them. One would think I would try that in this situation as well. I guess I come home and just go brain dead.
Thanks guys. I'll give it another shot.
I like the impact solution set to rattle the anvil back and forth. Falls off right in your hands. Otherwise tap and wack is the way to go.
1 - 12 of 12 Posts
