okay, heres what happened. i pulled the carbs bowls off. did the measurements per the directions on sheps site, wedged a screw driver under the float and adjusted them up. put it back together and tested with some fuel. no leaks. started the bike and set the idle. no leaks. drove it down the drive way (the exhaust fumes were killin me in the garage)everything was perfect so i put it back in the garage. 10 min. later it started to leak. so i drained out the gas again and pulled the bowls again, this time i pulled the float out and tried to bend it under a heat lamp to make it a little easier... snap. f_ck. i broke the float off the hinge. being that i'm cheap and always in a hurry i used an old soldering iron to melt the broken pieces together perfectly. i realized, thru my conversations with stitch, that my problem may not be in the floats but in how the carbs are sitting. when i dropped the back end the engine and carbs pitched forward so the floats will never be correct. of several options to correct this the easiest one i could do was drop the front end to level the motor and see what happens. so i have done that but i ran out of time to test it tonight. next 2 days are packed so i'll put some fuel in the tank on sunday and see if i'm leaking. (i really really hope i'm not, this has taken up way too much time)
