I've been tracking down an intermittent problem with my left turn signal (right works perfectly). My most recent observations indicate the following...
There seems to be some sort of flaky connection in the turn signal switch. When I move the switch a little - not enough to activate the turn signal - the left running light flickers a bit as I move it. If I end up with the running light off, the turn signal doesn't light up at all on the front, and either blinks slowly or is just on steady on the left rear. If the running light is on, the turn signal operates normally.
Clearly there's a loose or dirty connection somewhere. Where do I start? Does the running light wiring go through the turn signal switch? Should I just open up the whole thing and clean every connection I can find? I've seen a few threads about aftermarket switches, or adapting switches from other bikes. I don't feel a need to do that, unless my existing switch can't be fixed for some reason and needs to be replaced.
Thanks!
Thanks!
