Bike has started, idled and ran real good for about a year and a half now....I've done just about EVERYTHING to rebuild it both mechanically and comsetically EXCEPT for anything to do with the engine itself:
Well I ride it Saturday and it runs great.....I go out Sunday morning to start it and I hear this horrible dull,deep, whirling sound that sounds like it's coming from the back of the engine...it will whirl around for a few seconds then I start hearing some major clunking that AINT good !!! The sound does get faster as you rev the engine....if you put the kill switch to off and just crank the engine you do not hear the noise, you only hear the noise when the bike has totally started and idling.
I know it's difficult to diagnose over the internet without actually hearing the noise but my guess is it's the cam chain...I know I need to drain the oil to see if any metal is in there and that will "help" answer my question. I also know I'm going to have to drop the engine and open it up to tell for sure but the oil might give me a real indicator.
Another issue although it DID run great until now is that I've always smelled gas in my oil...when I'd go to check the oil level I can smell it everytime.....I know my carbs are spot on as the bike RAN great until yesterday...the oil just smelled. I guess my question here is that I've read before where if your carbs are ok and you always smell oil that you have another internal engine issue here ? Is that true and what could internally be causing THAT issue.
I'm trying to determine if this thing is actually worth fixing....let's say the engine isn't all ground up inside due to a cam chain and I get that issue fixed.....do I also have another inner engine issue causing the oil to always smell like gas that I'm going to have to deal with as well ??
My thoughts are that if I need to do more engine work other than a cam chain (to fix the gas smell in the oil) that I'm not gonna do it.
I guess I will drain the oil, drop the engine, open up the back and have a look....it certainly won't hurt anything IF the engine is toast already !!
