It's possible to use a bearing puller on the output shaft bearing, but what about the input shaft ?
last time around I put the bearings in the freezer overnight and then hammered them in square using a large socket and rubber mallet and a lot of foul language.
Thing is, that was before I'd started to build the engine up from scratch, this time, I'll be wanting to do it with just the gearbox out, without removing the crank etc.
is liquid nitrogen the answer ? or take it to a machine shop to get them to press the bearings in ?
any tips most appreciated
