441 - 460 of 486 Posts
Its not the jetting its your bike
You have already run a,185 it does not work
The local harley shop has a dyno and yoy dont meed them to tune it
Just the results yours is the only bike doing this and its been weird
since day one
Just try lifting the needle 1 or 2 instead of bigger mains
charles
cutterscustomcycles.com/
6815 Knightdale Blvd, Knightdale, NC 27545
(919) 217-7688
can dyno your bike and give you a chart
make sure the do a fuel curve each side
whne he changes the sniffer from one side to the other (unless he has 2) have him switch the coil pickup from one to the other
the dyno will show if there is a spark breakdown fro side to side that way
one pull each exhaust pipe so we can see the diff
that and the rwhp should tell the tale for once and for all
Discussion Starter · #443 ·
That 185 was with the restrictive exhaust I had on it. Exhaust is opened up now. I'll give the knightdale place a call one weekend when I have some free time and the weather isn't frigid.
Charles.
Just got through installing Murray's carbs on my 81 CX500 C which are the easiest installs I've ever done had a little trouble with the throttle tube and the cables Murray talk me through that I can't believe the acceleration the power so smooth I believe it vibrates less I can see out of my mirrors now it's amazing how much acceleration I have it's almost scary at times never thought you'd be possible to pop a wheelie on a CX I try not to do it but the bike is so much fun now I can't believe it I would recommend this mod to anybody it's a very simple install and Murray is the most helpful person I've ever had a chance to talk to you on the phone thanks a lot Murray have a good day. bill
Those chinese pwk carbs are total crap you wont find 2 that run the same
The brass fuel fittings pull right out of the bodies
The PLASTIC idle screws snap as soon as you touch them
The jets they send have no numbers on them so you have to guess
When you ask them for others you get no answer
Other than the leaks from crappy floats i cant say much more
You pay for what you get and on those carbs
Have fun
I finally emailed Murray and bought some carbs. Just installed it on my 79 CX500 and was not difficult at all. I just need to adjust the slack on the throttle and add the clutch springs recommended by Murray and I'll be smiling all summer long. Also bought the curved pipes too to go with my emgo shorties. Easy to install and Murray is a great help. Thanks again! Auto part Engine Motor vehicle Fuel line Vehicle
https://photos.app.goo.gl/xmjrWuUQBctobwP68
I'm almost to the "Ask for forgiveness, not permission" point with these carbs. Pretty sure my SO would have me sleeping in the shop with my GL though :vs_party2: Maybe part of this winters tweaking....
Just ordered the new Carbs from Murrays. I'm new to the CX500 club and excited to be a new member of the community! I don't even have the carbs yet and murrayf has already been very helpful! Thats service!
I was so happy with my carbs from Murray for my my 81 CX500 I bought a set for my 74 SOHC CB750. I love old bikes but dealing with 40 years old carbs suck; carb joke. It was great to see that Murrays sells his carbs for other bikes. Super easy to install and started quick. You really have to hold on when you accelerate. Like my cx you can feel the front end lift up when accelerating. Great job Murray!
Auto part Vehicle Engine Car Automotive exterior
Auto part Engine Vehicle Suspension part Suspension
Land vehicle Vehicle Motorcycle Motor vehicle Car
Land vehicle Vehicle Motorcycle Motor vehicle Automotive tire
Murray's on a 650
Land vehicle Motorcycle Vehicle Motor vehicle Car
I've had Murray's on my bike for some time now and am only getting around to posting. I'm definitely a fan, everything they say is true. You know you want them.
I get around 38mpg on my bike now, but the root cause for that has been established earlier in this thread I believe.
My question is, not having ridden a 500 with Murrays on it - will I ever be happy with anything but a 650 now? It's a real question as I look into future builds. Riding a Keihin-powered 500 now is pretty disappointing.
Thanks to all the forum contributors out there, you guys do awesome.
I'm trying to convince a friend of getting some carbs for his CX, he's happy with the Keihin, but he wants more reliability. As I'm quite lazy to read the 46 pages tbh , can someone resume the advantages?
Also, are they compatible with the stocks covers or does the airbox have to be empthy or dissasembled?
The Mikuni cards are much easier to maintain and adjust. It takes me less than 30 minutes to do so. I had to remove the airbox for installation and this does take some time.
Why would you recommend a product you dont know about
And dont want to do any research about ??
Btw the side covers can be retained
Why? Because I have similar mikunis in my cb and they are spot on and if there are 46 pages (which I read half) of people talking about this carbs, maybe it's an interesting topic
So far, the resume i thought is that improves the acceleration and gets some hp, also easy start. Am I right?
About the side covers, does the battery remain in the same spot or has to be moved?
There are ways other than reading all 46 pages of this thread to find out about these carbs, I'm pretty sure you could just call Murray. Just a thought.
battery is relocated usually if side covers are used its relocated 90 degress and set on the air box support play
horse power torque and starting are improved as is ease of maintenance and they are all new including new intake manifolds
