1 - 6 of 6 Posts
guys,i cant work it out from the image.3 bolts that hold the final gear case on,if i remove the last 2 will it just slide off,or,is there anything to surprise me.
thanks
It just slides off. There are no surprises.
You may want to drain the fluid first if you have not already done so. It's easier when the drive is still supported by the bike.
edit
mm,read your edit too late.lmao.....its off.
i think shep may have replaced the fluid[ill check] if not....oh it aint much,ill drain it over night.
thanks again dave
edit
thanks again dave
I put new oil in.They don't take much and don't overfill as it can blow the seals.I'm sure the bolts/nuts came off easy.You are welcome
oh they did,i can tell the parts you interfered with.lmao////they come undone,everthing else iv touched needed a mini-grinder
1 - 6 of 6 Posts
