1 - 6 of 6 Posts
Final Drive on a 82 gl500i. How hot should the final drive case get? Oil level full to bottom of large hole. Riding at 65-70 mph, head wind 20 mph. Traveled about 75 miles non-stop, 220 lb. driver.
Ev.
Back when the original choppercharles forum was active we had a discussion on final drive operating temp. I think it was fall 2008.
I rode my '80 cx500D for an hour or so and then stuck a meat thermometer into the final drive oil thru the fill port. Ambient temp was around 80F if I recall correctly. And the oil temp was around 115F-120F. The results did not alarm those who participated in the descussion.
Hoppy
As above.Warm to the touch so that you can comfortably put your hand on it.I seem to recall I measured one last year on around 20 Deg C day and it was between 30 and 35 Deg C after a ride but will check again some time soon.
Note:I change my drive oil same time I change my engine oil around 3,000/4,000 miles.This is well before the normal service point but engine I use is oil is cheap a sis the Hypoid gear oil so why not treat the bikes nice
Ambient temp. makes a difference too. I've had mine run burnable hand temp - but I also run at interstate speeds for 600+ miles.
It's most advisable to switch to a fully synthetic gear oil - right now I run Amsoil in mine.
~Thom
1 - 6 of 6 Posts
