1 - 14 of 14 Posts
Hey guys and gals, I have been removing parts off my parts bike (amazing huh!! lol). How the heck do you get the fan shroud off? Do you have to remove the fan or what?
Thanks a bunch.
You have to take the bolts out holding the engine brackets. It's a bolt and a stud on each side for the cx but could be different for the gl.
On #13 and #11 there are two holes facing forward. Those are the bolts or nuts that you have to take off to get #8 off.
I have all four of those nuts off, but something seems to be binding at the top of the shroud (8). I am guessing that it is the rubber part. Maybe I just need to keep pulling.
Stubby,same procedure for the gl.
you have a rubber deflector up at the top.also your temperature wire runs through it,make sure its unplugged
Ahh that must be export models only Shep
we don need no stinkin rad shrouds
I've whipped a few off and some were easy as they had been 'lightened' by PO's while some were original and had all that rubber deflector stuff at top rear which made removal a bit fiddly.
IIRC the tacho cable runs through it and I think the wire to the oil light switch may too
Ah.You get cocky now Efan boy<Grin>
PS
I also love the fact I can get my rad off in seconds without having to fight with ruddy mech fans and shrouds
Makes getting to the front engine cover/Tacho etc a doddle.
Yep I threw the shroud away last week and remembered to fit a connector near the rad
for the fan, so removal should be swift and painless.
Mine are just Car bullet connectors sprayed with ACF50 or dielectric grease slapped on.Very fast removal
1 - 14 of 14 Posts
