1 - 7 of 7 Posts
Ok, so I did the bypass on my '79 CX500D a couple of years ago, and I know I'll never give her up. But my son recently acquired a CX650 and we are in the middle of replacing the stator, cam chain, mech seal and starter clutch bearings (aka, the "quadruple bypass"). There will probably come a day when he will sell this and subsequent new owners will inevitably come to this forum and wonder to themselves, "has the bypass been done or should I drop the engine and do it?"
Now I like to save documentation of the repairs and upgrades I've done. I have a file with parts lists and I record the mileage I've put on between oil changes and all that, but documents can be lost or simply not passed on.
Has anybody found a good way to indicate in a permanent way what major maintenance or upgrades you've done? I was thinking perhaps one of those durable metallic stickers with the date, mileage and work performed, but there is probably a better way.
any ideas?
I don't think there is a good way of documenting. As Murray said look for a gasket change but really that could show the least repair instead of everything that could be done.
I document my own and if the next person down the road doesn't believe what I have done then they can do it again for peace of mind. Usually I keep a photobucket folder showing the pictures of the engine coming apart. I hope to be the next person doing a triple bipass on my gl650i and cx500 supertanker knowing that i've already done this in the past. These are my keepers.
The replaced gasket tells you that somebody has been inside, but not what they did. I'm doing a triple on one now that showed newish green gaskets at the front and rear cover. The camchain is stuffed and the stator is a dark red so I'd say neither were replaced leading me to conclude it's had a new mech. seal recently-ish.
When I did irrigation I used to tag solenoids with the plastic from ice cream cartons with the relevent info stamped on with alphabetical punches. Perhaps a tag like this may help?
Discussion Starter #7
I've got it! I can create a new google account with an email address specifically to the bike, then upload everything to google docs and email. Then I make a metal tag and scribe it with something like: "go to [email protected] for a detailed history of maintenance and upgrades." with the password, of course.
1 - 7 of 7 Posts
