Hello all,
Well I put that mechancial seal in the back case. I spent 2 days trying to figger out
how I would enlarge the water pump hole for the larger size mechanical seal that we now use.
I come up with something. I used a 18 penny nail that I cut the head off of it
and split it down the middle about 3/8 in. Then I cut about 7ins. of emery cloth and cut 3/8in slice
of the side of it.taking this 3/8in. piece sliding one end thru the split in the nail and wrapped
the lengh of emery cloth counterclock wise around the end of the nail. I then put the nail in my drill. then put
the emery cloth end in the hole and run the drill until hole was the size I needed. 100X emery cloth.
I didn't go back passed the weep hole. If you work at it the hole will be round.I put a sealer on the
mechanical seal. It looks good. I let you know if it works. OLDBIE
