Hello! This is my first post on this forum so forgive me if I do anything wrong. I am also extremely new to motorcycles, so my knowledge may be limited so forgive me for that as well. I do have some experience with engines from my engineering degrees, but nothing very hands on. I am a huge fan of the forum and it's helped me immensely so far with the project. Sorry for long explanation but figure its best to be detailed and explain everything I've done to eliminate tests I've already performed.
Recently I have decided to work on a 1978 Honda CX500 standard that my grandfather acquired in that same year. The last registration was from 1981 and the bike only has 1500 miles on it and seemed in decent shape. I've started doing some work on the bike (repainting parts and cleaning, getting a new battery, beginning to modify rear frame and have spent a good bit of money on new parts). Obviously I should not have done this before making sure the bike was running well but here we are. At this point I've spent 10s of hours on researching as well as money on parts so I would like to continue the project. My grandfather also assured me that the bike should be able to run and in good condition before starting.
I decided it was time to get the bike running so I got a new battery and hooked it up. Took me a while to get power to all the parts before realizing there was a broken fuse. Switched that and all lights came on and seems all blinkers and such worked. Tried to hit the push start and if I remember correctly the bike turned over for about one second then stopped and buzzed by solenoid. Figured it was solenoid by checking with multimeter, tried to take apart and clean with no luck so got a new one. Under $15 so nbd. Also figured it was issue because I wired directly from starter to battery and the starter turned (I did take it off of the engine to test). I was told this was normal, but my battery does drop from about 12.7 to 7-8 volts when I push the start button and have the multimeter connected directly to the battery. Also checked wires from switch to solenoid and didn't get any Open Loops with multimeter test. Anyway, not really important for post as I now believe all electrical problems seemed solved for now. Only explained to show how the bike turned over then stopped.
I decided maybe the problem was with the engine itself as when I had the starter on the engine and wired directly it would make noise at the starter but not turn over the bike. Figured it was seized so I grabbed a socket wrench and tested the front manual motor crank under the radiator. It would move a little then stop when turning clockwise (from front of bike). I opened the side engine inspection bolt and looked in and could see the parts moving while turning the front, but eventually they would stop and I didn't want to force it harder than I already was. The bike was stored in WV in the USA, so it is rather humid, so it makes sense moisture could have gone up the exhaust and carbs and caused things to seize after not being ran for like 38 years. Figured it maybe was piston rings so I added a 50/50 mixture of Marvels Mystery Oil and diesel (about 1.25 oz of fluid to each spark plug hole) and let it sit for 4-5 days. Tried using manual crank again with no luck. Also tried putting it in highest gear I could and rolling back and forth but the back rear wheel skids after about a quarter turn. I can roll bike fine in neutral as well as in gear with the clutch pulled in. I am not sure if this is related but I have been having trouble with the shifter and it seems like parts don't always want to engage and ill press down or up and nothing will happen/click. Took me about 5-10 minutes of wiggling it around with my foot to get it back into neutral. Figured maybe some things are just loose (or I'm really really bad at lifting my foot up and down, like I said I'm completely new to bikes).
So I guess my main question is how can I unseize the engine (if that's really my problem).... are there other things I should be testing? Possible it's locked at the drive shaft/final drive? CAM chain? I'm definitely out of my league when it comes to this stuff so just wanted to make sure I am not overlooking something simple/an easy fix. I'd really prefer to not have to take the whole engine out and take it apart as I'd have no idea what I am doing. If I have to I will, but only as a last resort as I'd get in there and not have any idea what to be looking for. What I also am confused about is how I got the bike to turn over for a second when I first put in the new battery then it stopped. In my mind, if the pistons were seized and attached to the cylinder walls then the engine wouldn't have turned over at all before stopping. Maybe only one piston is stuck and it was able to move a little before stopping? I'd like to learn more about it, but realistically may be better to just get a whole new engine. Right now I am just trying to get the bike to turn over (then I'll tackle the carbs and such). Thanks for any help and taking all the time to read my long message.
