Looking for some advice regarding my 1982 GL500 which starts and idles fine until it warms up. Once it's warmed up it idles fine for a minute or less and then it speeds up to 2-3000 RPM or so for a few seconds then slowly goes back down to idle (cycles this way). The bike did this when I purchsed it so I cleaned the carbs using an ultrasonic cleaner and Larry's carb book. Carbs were clean for a 28 year bike; the only thing I found during cleaning is one of air cutoff valve diaphrams was split.I replaced all the rubber parts. Carbs also seemed to be all original. Idle mixture screws are set at about 1 5/8 turns which is what Honda recommends in the service manual. Larry's book says to start the idle mixture screws at 2 1/2 turns - could that be my problem? The screws have the cap on them preventing me from turning them more than 7/8 of a turn (unless I take the float bowl off).Carbs are syncronized at idle then when I rev the engine the Carbmate syncronizer LED's go to the red on the right cylinder. I have checked the valve clearances and they are spot on.
My suspicion is that it's carb related and it's most probably my right carb which still has some clogged passages.
What should be my steps to diagnose and fix this issue?
Thanks in advance.
Roland
Thanks in advance.
Roland
