Thanks for the replies guys
Might be electrical. Had this problem on another bike when the rectifier went bad. Does it charge okay?
Otherwise, where does it idle when it's warmed up? Or does it just die? If the electrical seems okay, maybe set the idle high, and slowly lower it. Maybe it's set too low?
think the electrics are ok, not checked voltages but will tomorrow. battery hasn't ran out yet but it's only been a few days. have had to keep restarting it (30 times a day) so it must be charging or it would be dead quick (it's a cheapo one)
yeah I think I have to adjust the idle setting, need to do my research on that. if i leave the choke out full on startup, it runs fine at about 1600 and will even run for a bit when I put it back in again too - but once I get going it won't, unless I keep the revs up.
It could also be a vacuum leak. Does your bike have a vacuum-operated petcock? If so, check the vacuum hose between the carbs and the petcock for splits at the ends or other leaks. On occasion the petcock can develop a vacuum leak but still seem to operate normally otherwise.
What kind of bike do you have? This would be good information to have in everyone's signature.
it does feel like it's running out of fuel, mines a '79/80 Z think it's the earlier petcock without the vacuum ? the rubber hose between the tank and carb doesn't leak, but I've got no clips on it atm, so will get some and check if that helps.
really want to strip the carbs down, but only source of good carb bits seems to be Randakks in the US and I'll need to wait a while for postage. not sure if I can re-use old gaskets with some sealant in the meantime. will also check the plugs and compression readings tomorrow.
