The previous owner had for some reason taken off the box that covers all the electrical connectors on my '82 Silverwing Interstate. Fool that I am I decided to put it back on today figuring it would help keep everything dry. I disconnected the terminals, cleaned them up a bit, and then reconnected them inside the box. Now, I'm having some electrical problems. With the key set to on I have both turn signal indicators lit up, the front and rear turn signals are on, and the high beam indicator light is on. The oil pressure and neutral lights do not come on, unless I switch the headlight to high. (The headlight doesn't switch to high.) Neither turn signal works when I move the turn signal switch. I'm fairly confident I have it connected as the diagram shows and all fuses look good. Now, what did I do and how can I fix it? Is it a loose ground somewhere or did I fry something?
Thanks for your help in advanced.
