You'll probably have to e-mail the seller for dimensions. We know that some Ducati and most Kawasaki K6R ? fans will work without trimming, personally I used a fairly large fan from a Suzuki GSXR1100 but since it was so close we ended up trimming that 1/4" of cam tip off that isn't used anyway so the OEM fan could still be remounted in future.
There's a thread over in the tech forum somewhere with a fair amount of info.
A GL650 fan will not work with the stock 500 cam and will need extesive work to mount on a 500 radiator.
even a 650 radiator needs to be tweeked.
I put a 650 radiator and fan on my GL500, but I had to use the 650 cam and tach drive too.
I would go with the other fans people are using.
Thanks for all the information. I kinda thought the 650 fan would be to good to be true on the 500. Thanks again. Billrod
