1 - 16 of 16 Posts
1980 Honda CX500C
Ok, I converted to electric two years ago, and I believe I used Shep's write up on the topic. I cannot find that write up, and I cannot remember which electric fan I wound up using. I kknow it was the most popular choice at the time I did the conversion, and it required me to cut off the end of the camshaft. I believe it was a Kawasaki Ninja 600 fan, but I am not sure :/
1980 Honda CX500C
1980 Honda CX500C
Ahh. I'm pretty sure I used the Ducati 916 fan. I hope the fan has some kind of ID marks on it. If/when it dies, I want to replace it with the exact same thing, as the mounts I made are welded to the steel.
The link you posted Shep works, but the other links, and even the link I have for your forum don't
What up wit dat?
id love to get more info on the screw in temp switch that i saw on another thread... anybody have any info on that... i have a 96 ninja fan mounted but i never wired it to a temp switch... i have a toggle switch to manually controll it but id rather have it wired in
Just wired mine back in today
I use an 80C switch on a relay to control the fan.
It isnt the simplest method but I figured that it will last longer
switching 130 milliamps to a relay coil than the full current of the fan motor.
As I only need small gauge wire for the relay coil, I soldered the leads to the switch
Now that looks like a fan!
What kind is it?
1980 Honda CX500C
Discussion Starter · #14 ·
Kind of reviving a dinosaur here, but it seems all of Sheps sites are long gone.
That fan finally died. No idea what one I used, and I can't find Shep's write up anywhere.
1980 Honda CX500C
Discussion Starter · #16 ·
That's the one!
All the sites listed earlier in this thread are gone, didn't realize it had been moved.
1 - 16 of 16 Posts
