The kits aren't bad as long as they are the ones with ballasts. As for glare yes the bulbs in our motorcycles aren't 100% ment for them but if you aim it right it will not glare or blind people. As for the blue lights with kids. There are a lot of idiots out there. With hid you can pick the color temperature which should be white. If you're putting blue lights in then expect to be pulled over at some time for it.
Mine is a Euro FX. I guess they are sold in Indiana somewhere.
Well, I wasn't referring to the blue light as being the problem...just an example most would know since they're annoying.
Yes, you can aim your headlight lower to help alleviate some glare...I still think you'll get better lighting performance out of a properly set-up standard set.
But again, just my $0.02.
That's how mine is.... New silverstar, but the low beam can't even shine 10 feet. I've even tried to hook it directly up to the battery.... It's getting proper voltage and it looks alright up against the garage wall, but on a dark back road all that light gets lost. The high beam is pretty good though.You would think. But I have used sealed beams and H4's and all properly set up and it's like trying to drive holding a AA maglight. The HID I have is doing the job, I see a lot more and I haven't noticeably pissed anyone off.
yep, that'd be the ones with projectors. i agree with jasonh on this that if you're going to do it you should do it right and get projectors for your hid's. that's what they were designed for. will they work without the projector? yes. will they work better with the projector? yes. i have projectors for my fz6 and the light output is unreal.
Is there a projector housing kit available?
The package should be here today or tomorrow, so i'll be letting you know how they work soon!
The bulb is aimed properly..... The only other thing I can think of is that there is something wrong with my reflector?
Well guys,If I had the money I would probably try this kit:
http://www.theretrofitsource.com/product_info.php?products_id=227
The projector is only 5.35" deep. I think that's deeper than the stock light, but I'm sure there is some MC light out there that would work. Or just make a custom fiberglass housing for the projector....
I've also been toying with the idea of LED headlights. That would require some trial and error though (and $$$)
