Hi yer, first post on here. At the moment I'm sorting out a cx500 for my daughter and I've never had to deal with a watercooled bike before. So, I'm replacing all the coolant and so fat have emptied the radiator and flushed that through, put in so chemical stuff to clean the system out and then I'm going to drain that so I can flush through again and fill the system up with distilled water and anti-freeze.
Anyway, my question is, so I completely drain the whole system? as in take the radiator off, and drain the engine by undoing the drain plugs on the cylinders? and also, what is the simplest way to flush out the overflow tank? I took off the bottom hose and undid the cap, ran so water in from the hose pipe but it didn't seem to come out of the bottom union.
