11-19-2010
I have a 1982 GL 500i with the 32-spline gear (looks like a sun--located at the center of the differential/final drive) that has busted teeth; the matching side at the center of the Rear wheel (unless I have the position of those two reversed) is also stripped of splines. I have to replace that pair and I wonder if the piece that is bolted to the right-side center of the rear wheel is available (readily) at some parts supplier-- also I would have to get the gear for at the differential side.
I am not opposed to replacing the entire differential via ebay parts etc; I have not found a source for just the part of that set that bolts to the rear wheel center.
I am looking for a source for those parts, and I am wondering how much interchanging I could do between models and years.
Do the CX bikes have exactly compatible parts, how about with the goldwings, --years?
Thanks all, very much.
