So I'm about to start cleaning my carbs (but for some reason have not been able to find any carb cleaner solution) and decided to change my oil just make sure it was good to go.
I had changed my oil earlier this year but couldn't find a filter for it so just changed the oil and not the filter. I forget the exact oil I used but it was a dark colour.
When I changed it this time I tried to follow everything exactly to the book.
I first started the engine and let it run for a bit. It was running fine and idling around 900-1000rpm. With choke up it was running around 3500.
I drained the oil and let it drain for about 40min (book says 20min but I decided to be safe and let it drain completely).
Changed the oil filter and cleaned the oil filter parts with this cleaning solvent:
http://www.superkleendirect.com/superclean.aspx
Dried it thoroughly.
Torqued the oil filter bolt back to the specified amount.
I then used this oil:
http://www.canadiantire.ca/AST/brow...torcycle%2B-%2B%2BFour%2BStroke.jsp?locale=en
It looks very different than the oil I previously had in there. More light brownish colour. Put about 2.5 litres in and made sure it filled to the right height.
When I ran the engine though the rpms were much lower. With choke up it ran around 2000rpm and idling around 500rpm and it was struggling there. You could hear it turn slowly.
Did I do anything wrong here? Should I change it again?
