21 - 22 of 22 Posts
If the terminals inside the headlight connector are loose on the headlight's pins you can tighten them by gently squeezing them so that the edges of the rounded parts are closer to the flat side. Sometimes putting a small screwdriver into the connector to push against the terminals and close them a bit but you may need to remove the terminals from the connector to get at them with pliers. There is a little tab bent out from the back of the terminal that latches in the connector that you will have to push in to get the terminal out (& make sure it is bent out to latch the terminal when you put it back in).
BTW: Welcome to the forum. Please add your location to your profile and your bike's model and model year to your signature so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
21 - 22 of 22 Posts
