Have you checked the main fuse (located under a cover on the side of the solenoid)? Those so-called "dogbone"(open link) fuses deteriorate over time and can develop cracks that can open depending on the temperature or engine vibration (I've even heard of a few that disintegrated when touched). The common advice here is to replace the original fuse with a modern blade type fuse in an inline fuse holder
Your brake light is on the same fuse as the turn signals and horn but the tail light is on a different fuse (should be the same one as the marker lights in the front turn signals and the lights in the instrument panel) so if both the tail and brake lights (separate filaments in the same bulb) go out the problem could be a bad ground (green wire) connection where the light plugs into the bike's main wiring harness under the seat.
