1 - 3 of 3 Posts
Hi
What options are there for putting spoked wheels on a CX650 custom. I know these are different, wheel wise, to the general cx/gl family,
Thanks
Jay
easy peasy
get a vt800 shadow rear wheel and brake plate
the rear rim uses the same size tire you have now
then you need to get some 20mm od 17mm id tubing i get mine from parker steel /metric metal
cut 2 pieces one to go thru the rear wheel bearing to bearing and one to go thru the brake plate
the rear wheel will now go on using teh stock cx650 rear axke
but since its upside down to how it goes on the shadow you will have to make a new brake stay
for teh front get a cb750 dohc spoked front wheel and brake roto it will go right on
and i think if i remember right you need the cb750 front brake caliper mount as well
when done it looks like this
198947
198949
see how the brake stay is flipped up instead of down that is because the wheel is actually upside down but no one will notice
and it works the same
Discussion Starter #3
Cheers Murray. Have just got a good deal on some 18” boomerang wheels off a cx650 Eurosport which I believe will fit.
1 - 3 of 3 Posts
