Hi,
Just got CX650c. Its new to me having just had CX500 euros so far.
After some trouble getting it started - turns out reserve does not work on the fuel tap (aaagh) - it runs real rough and wants lots of choke.
Checked the plugs and one of them was a little bit "yellow" spark. Replaced the plug with same result. Decided to swap the coils with the working well coils from my cx500 eurosport (same exact coils). This seemed to help but the bike still rides crap.
Riding down the road its spitting and jerking (even on choke), with the choke off same behaviour but will rev a bit better....at about 4k revs its done.....revving the bike in neutral it revs to about 6k revs but under protest and lots of stuttering. So I'm ruling out stator problems as it will rev beyond 6k revs but thinking fuel starvation etc
Took off the carbs...every thing clean..all jets look good....pistons move smoothly....mix screw set ok.....didnt check float height or didnt open the air cut off or accelerator sections (maybe a mistake !!)
Then modded the fuel tap to be non-vaccuum - its leaking a little bit around the little bowl (dodgy o-ring).
Bike still not running well......farting and splutting with the choke on...with the choke off same behaviour with lots of popping and almost backfiring ????????
I still suspect something in the carbs and am hoping to get carbs off a working bike a friend has in a week or so...if the problems remain then I'm maybe thinking electrical problem around a bad connection to maybe the coils somewhere or else the sparker units or something ??????
Anyone ever seen a 650 custom with issues like this before ????
Any help/advise appreciated.
Not trying anything else with my carbs till I test the bike with my friends carbs first !!
Eric.
Eric.
